Author Topic: Key fob 'programming'  (Read 2506 times)
Offline andyr
« on: 06 December 2011, 21:52 »
Following on from Jimble's 'does your boot lid "pop"' thread, got me thinking about my (our) key fob's.
We have two - Like I assume, most people here - And mine just unlocks the car and starts the ignition whereas the missus' fob goes one step beyond, when the car goes above a few mph, all the doors lock. I first assumed it was when her fob was used to start the car, but I now find that if she unlocks the car with 'her' fob, but I drive - with my key fob - the car will lock when reaching that certain speed.
I was just curious as to what others key fob's did and why I have only one fob that does this trick... Just casually looking at both fob's, they seem identical...
A question :
Can the fob's be programmed on the fly by some means to switch the facility on/off (key in ignition, indicator to left, right trouser leg rolled up etc etc) or does it involve a trip to the stealers/vag-com intervention??
Mk VI Black Pearl GTD.... No Frills, replaced a Black Pearl PD150 Bora, which in turn replaced a Dragon Green VR6 which followed a Dusty Mauve MK III 8v Gti.
Offline Jimble
Re: Key fob 'programming'
« Reply #1 on: 06 December 2011, 22:52 »
I had no idea the golf fobs could be programmed to affect the cars options?!? :huh: i know my car locks at 5 mph with either key but thats a setting in the mfd.
Hmm interesting....
Offline p3asa
« Reply #2 on: 06 December 2011, 22:56 »
You can set the doors to autolock on the MFD. Are you saying yours doesn't do it when you use your fob to unlock it?
My set up is like yours altho I have the key that does everything.
I just presumed the car recognises which fob is being used so works to how that key has been set up.
I kept meaning to put the other key in the ignition and see if the MFD does have slightly different settings i.e. the auto function is on etc.
Offline andyr
« Reply #3 on: 06 December 2011, 23:15 »
So, It's all done on the mfd then, I'll have to check it out using both keys to see if there's a difference....
Still getting used to all this MK VI malarky........
I'll get me coat..... :laugh:
Offline Keithuk
« Reply #4 on: 07 December 2011, 00:55 »
When I first had mine the doors would lock when you get to about 10mph it was very annoying so I turned the autolock off in the MFD settings.
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline mkviken
« Reply #5 on: 07 December 2011, 09:51 »
the car does remember the settings each key or driver select.
when i picked mine up the dealer said each key remembers footwell light %, locking settings and seat position if they're electric seats!
I've not tried it though as only i drive the car really
it would be great if AC temp and radio presets were remembered for each key too!
this thread has reminded me i need to activate the auto lock feature on mine.
Golf GTI 7.5 230 white silver
Offline p3asa
« Reply #6 on: 07 December 2011, 10:56 »
Thanks for that. Its a pain when I have to use the spare set and a lot of settings are different.
Offline Belix
« Reply #7 on: 07 December 2011, 15:31 »
seem to remember my dealer saying it can set the mirror positions too if you have the mirrors with memory function. Mine are not "memory" mirrors, so I've not tried.
Offline andyr
« Reply #8 on: 07 December 2011, 17:36 »
So I checked both keys on the MFD today and the settings were the same for both  :huh:
There was no tick in the 'auto close' for the wife's key when we *know* the doors lock at 15kph!
I've since put a tick in the box for both keys but not driven yet..... And when I remove either key/lock/unlock the car/re-check the MFD data, the tick's are still showing in the auto close box! So why didn't it show for key that *did* auto close before???
One answer perhaps is:- At an earlier date, the Auto close was enabled for the one key.... Then an ECU update was carried out and removed the 'tick' from the box in the display data, but the facility still worked??
Tomorrow I are be mostly scratchin me 'ead  :laugh:
