Author Topic: Does your boot lid "pop"?  (Read 3554 times)
Offline Jimble
« on: 06 December 2011, 11:38 »
As above, when you open the boot either by the handle or the key fob does the lid pop up? I'm sure mine used to pop open about half an inch or so, my car is in the garage again tomorrow to have the camera replaced and some clunking from the rear end looked at, my boot lid doesn't seem to line up with the bumper under the lights anymore and was wondering if the clunking and misallignment could be down to a knackered boot latch? :sad:
Offline mattlittle
Re: Does your boot lid "pop"?
« Reply #1 on: 06 December 2011, 12:42 »
My boot opens an inch or so when you press the boot release on the key fob.
Offline andyr
« Reply #2 on: 06 December 2011, 13:11 »
Boot lid stays completely motionless with either key fob boot release or opening by handle.
As I understand it, using the key fob only unlocks the boot - not opens it - therefore I would assume it would still need opening by the handle?!?  You wouldn't expect any of the doors to move in any way or fashion if you just 'blipped' the key fob?
Mk VI Black Pearl GTD.... No Frills, replaced a Black Pearl PD150 Bora, which in turn replaced a Dragon Green VR6 which followed a Dusty Mauve MK III 8v Gti.
Offline Keithuk
« Reply #3 on: 06 December 2011, 13:12 »
No it just opens of the catch when you use the remote or unlock all door of the drivers door switch. You have to press the remote button twice to release the second catch.
If you want it to open and lift automatically you have to fit Skoda dampers, search YouTube there are loads showing how to do this?
MKVI GTI Hatch Pop Installation
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline mkviken
« Reply #4 on: 06 December 2011, 14:19 »
yep mine definitely doesn't move at all
our focus boot  moves about half an inch when you press the key or the boot lid button but the golf doesnt.
Golf GTI 7.5 230 white silver
Offline Buck
  • Das Auto
« Reply #5 on: 06 December 2011, 16:44 »
Mine pops but about a 1cm or so
Offline KennyGTI
« Reply #6 on: 06 December 2011, 16:51 »
Same here, don't know why or the reason for it?
APR Stage 2+
Offline Jimble
« Reply #7 on: 06 December 2011, 17:22 »
Thanks guys, i think whether it pops or not may be to do with the bump stops, the last time it was in it looks like they have pushed them all the the way in to try and (failed) to find the clunking, i've adjusted them and it does pop a bit but not like i remember, i still think the latch might be buggered! :huh:
Oh well, god only knows what it'll be like after they've had the boot apart to replace the camera! :sick:
Offline Keithuk
« Reply #8 on: 06 December 2011, 17:59 »
Yes is maybe adjustment.
If you press the remote hatch lock once it leases the catch and opens about 1cm as said. If you try and get your fingers around the edge to lift the hatch to open it it won't unless you lift the VW badge. If you press the remote again it releases the second catch and you can lift the hatch with your finger around the edge but the badge is easier.
Offline p3asa
« Reply #9 on: 06 December 2011, 18:07 »
I've just tested this as I needed something out the car anyway.
Once click of the fob and the indicator lights flash but no noise or movement comes from the tailgate. You can open the tailgate though.
Two clicks of the fob and you can hear the mechanism move in the tailgate but it certainly doesn't appear to pop. However looking on the MFD the tailgate is marked as open and the inner lights on the tailgate don't come on but I certainly couldn't see it pop or move when I tried it out.
