Quote from: Len on 06 December 2011, 12:03They have to be noisy!Air will be forced in and out! Trust me that will make a heck of a noise!I trust you len
Arent they just run flats without the dressing?
Quote from: clipperjay on 06 December 2011, 12:25Arent they just run flats without the dressing? I see the similarities but a run flat can only utilise very little space on standard sized rims, run flats are not soft and absorb pretty much nothing, to drive normally you are still reliant on the air filled tyre.
Quote from: SoundillusioN on 06 December 2011, 12:31Quote from: clipperjay on 06 December 2011, 12:25Arent they just run flats without the dressing? I see the similarities but a run flat can only utilise very little space on standard sized rims, run flats are not soft and absorb pretty much nothing, to drive normally you are still reliant on the air filled tyre. okay flappy bits weaker on run flats then
I imagine that the finished product would have a sidewall.Quote from: Len on 06 December 2011, 12:03They have to be noisy!Air will be forced in and out! Trust me that will make a heck of a noise!Where is the air being forced in and out?
