Author Topic: Which gearbox for better cruising/mpg on 16v gti  (Read 5508 times)
Offline Shivas Regal
« on: 05 December 2011, 21:11 »
In these times of extortionate fuel prices, I would like to have the option of cruising in my valver rather than ragging it everywhere.
Was wondering if there is another gearbox that will fit or better 5th gear that can be used to improve mpg performance rather that acceleration.
Cheers guys
Offline The Mighty Elvi
  • I'm better than you today.
Re: Which gearbox for better cruising/mpg on 16v gti
« Reply #1 on: 05 December 2011, 21:14 »
If your a bit flush with the readies you can buy a Quaife 6 speed gearbox.
If not, iirc you can fit the 'E' gear from a Driver. Its longer than 5th.
If you go to www.brokevw.com
There is a full list of gearbox codes and ratios/final drives.
Take your pick.
Offline Ben Lessani
« Reply #2 on: 06 December 2011, 11:18 »
You could just drive slower :rolleyes:
Offline SoundillusioN
« Reply #3 on: 06 December 2011, 11:37 »
Yeah but even at 70, 5th seems a little short...
Offline clipperjay
« Reply #4 on: 06 December 2011, 11:38 »
02A 311 361 M £59.80
02A 311 158 R £94.21
From a bit of searching the Gearbox can have a longer 5th gear from a TDI or VR6
I got these part numbers but you will have to confirm they will go into the 020 box
They fit the Rallye not sure on 16V gti though if its the same box which I think it is i.e casing not internals then they will fit!
This is interesting good reading!
http://wiki.the-corrado.net/5th_gear_cog_change.html
Offline Sam
  • Sam I am
« Reply #5 on: 06 December 2011, 11:52 »
The most common swap is to a vr 5th, the 16v does have a really really short final drive - still built for acceleration rather than cruising on the motorway. No idea how the Autobahn loving Germans overlooked this.
« Reply #6 on: 06 December 2011, 23:04 »
Thanks guys.
I actually have a complete vr6 highline that I'm breaking.
Is the general advise to take 5th out of vr6 and pop it into 16v?
Offline Sam
  • Sam I am
« Reply #7 on: 06 December 2011, 23:09 »
Thanks guys.
Not as simple as popping it out! If it 'pops' chances are loads of other sh!t will pop out with it lol. There is a guide, I will try dig it out
Offline clipperjay
« Reply #8 on: 07 December 2011, 09:09 »
It is the easiest one to remove because the cog is right on the end of the box!
By the way you change one gear it does overall effect the ratios of the other four  :wink:
« Reply #9 on: 07 December 2011, 10:22 »
Surely that only applies if he changes the final drive.  Simply changing 5th wont affect the other gears, no?
