Author Topic: Starting problem  (Read 1838 times)
Offline Alps
Starting problem
« on: 08 May 2005, 23:50 »
ok this is a weird one!
try to start the car, all the lights go dim, clock even resets, like theres a big power drain, no turn over or anything
try again a few minutes later and it starts first time!
could this be the starter on its way out? how can I test?
cheers
Alps
Mk1 Rivage - 1992 Green
E55 AMG 2004
C36 AMG 1997- SOLD
MK4 1.6 SE - 1998
MK1 Rivage - 1991 Blue SOLD
Offline kniterider
  • had most, sold most and often buy more!
Re: Starting problem
« Reply #1 on: 10 May 2005, 10:05 »
sounds like the starter to me, if it started ok after a min or so with out dimming the lights/resetting clocks then id say the solenoid might be sticking now and then maybe shorting out?, the wouldnt be any harm in taking your starter motor off, stripping it and giving it a good clean etc, then re trying it... if its cured then youve saved your self some cash, if not go buy a new/recon one and fit it!!
 :grin:
Offline Alps
« Reply #2 on: 11 May 2005, 00:05 »
is it an easy job taking the starter off?
Alps
E55 AMG 2004
C36 AMG 1997- SOLD
MK4 1.6 SE - 1998
Offline ronnie'C'
  • MKVI GTi and a MK3 VR6 (lhd)
« Reply #3 on: 19 May 2005, 22:00 »
Sounds more like you have got a dodgy electrical connection somewhere, maybe starter motor but could be anything to do with the battery aswell.
Offline D Owen
« Reply #4 on: 20 May 2005, 09:48 »
My starter motor makes a terrible noise when it turns - I have taken it out and sprayed it with WD40 but after a week or two the noise returns.
To answer your question - itÂ’s not too bad to take it off. Of what I can remember there are two (or three) bolts that hold it in place and can be a little difficult to get to but once they are off then its quite simple to disconnect it from the battery (by the way disconnect it first :evil:)
Sugar79
« Reply #5 on: 20 May 2005, 09:53 »
Have you checked your battery earth??
My old Xr2i done that, trying to fit a alarm and my silly mate forgot to do the neg up properly on the battery, tried starting the car and all my lights came on and dimmed it was a massive power drain, matches what your saying is happening to yours.
