Author Topic: Power Steering  (Read 1070 times)
Offline KaneW
Power Steering
« on: 08 May 2005, 23:45 »
Hi guys,
Im fairly new to golf gti's so i wonder if somebody would be so kind as to answer a couple of questions, thanks.
I have a mk2 golf gti, with power steering. I have previously also owned a similar golf gti but without power steering.
I notice that the engine of the model with power steering seems to be 'tilted' backwards more - to make room for the power steering pump at the bottom of the engine.
Now my question is, do these engines that are fitted with power steering fit straight into a GTI which doesnt have power steering?
eg, is it only the mountings that differ? - so one could swap the whole lot - and it would fit straight in?
or is there something else which needs to be considered?
Thanks Alot guys
Kane
Offline Gambit
Re: Power Steering
« Reply #1 on: 09 May 2005, 11:07 »
PAS can be fitted to any non-PAS Gti. they both use the same engine and mountings. and they aint tilted differently or anything like that
Offline KaneW
Re: Power Steering
« Reply #2 on: 09 May 2005, 11:37 »
ah, sorry.
it just seemed that on this golf gti i have now, the engine seems to be alot nearer the bulkhead then i remember before with the other one.
as it looked like if the engine was tilted forward like on the other one i had, it wouldnt clear the ground.
so this engine will fit straight into any other mk2 is that correct?
Thanks again
Kane
Offline Gambit
Re: Power Steering
« Reply #3 on: 09 May 2005, 12:09 »
you've lost me. why are you wanting to do an engine swap now?
what year was your previous GTI? was it an 8v k-jet whereas your current one is an 8v digifant?
Offline KaneW
Re: Power Steering
« Reply #4 on: 09 May 2005, 12:30 »
the reason for the engine swap isnt really important.
but yes i think this current one is a digifant, that probably explains it.
