Author Topic: Ok this is wierd!!!!!  (Read 1393 times)
Offline mjamoose
  • I'm off a hunting! (for a head gasket)
« on: 08 May 2005, 00:31 »
In my last topic on this section of the forum (Possible Cylinder Head Gasket Porblem)
I detailed that the car was blowing white smoke, only mildly mind...
It stops doing it if the engine runs for more than 15 mins....
Is this now a major cause for concern? The temp is still fairly high, still above normal.
PS The car is a 1.6 Golf Driver (Mk2 1990)
Cheers! :shocked: :shocked: :undecided: :undecided:
WARNING DRUMMER ON THE LOOSE :evil:
Offline Mr Blue
Re: Ok this is wierd!!!!!
« Reply #1 on: 08 May 2005, 12:11 »
water or anti freeze burning off giving out white smoke??  :huh:
Offline mk1
Re: OK this is wierd!!!!!
« Reply #2 on: 08 May 2005, 17:18 »
If the engine starts and runs without misfiring and is not using coolant, I think you are seeing normal water vapour (steam) in the exhaust.
Steve.
Offline the_GTI_new_guy
« Reply #3 on: 09 May 2005, 22:01 »
must be condensation. White smoke that dissapears after a while is not worth worrying about. Black or blue smoke is the only real concern.
