Author Topic: Bonnet Dampers  (Read 3270 times)
Offline Bazza1975
Bonnet Dampers
« on: 01 December 2011, 07:13 »
Hi,
Has anyone here fitted bonnet dampers to their VR6 ?
I only ask as I bought some a few weeks ago but when I went to fit them yesterday I found that the bolt in the inner wing is actually a screw thread but the bolts supplied are something like M8 & M10's.
I phoned the company & was told that I have to screw the new bolts in place of the old ones & fit a washer & nut underneath ? Is this right & if so how do I get underneath the bolts to fit the washers & nuts ?
Cheers for any help.
Baz
Offline dom
  • Back in a Mk4
Re: Bonnet Dampers
« Reply #1 on: 01 December 2011, 07:26 »
Get yourself to a scrappy & pick up some boot struts, they work perfectly. There should be no need to fit washers & nuts.
Offline *tell*
Re: Bonnet Dampers
« Reply #2 on: 01 December 2011, 10:11 »
Offline Bellend
Re: Bonnet Dampers
« Reply #3 on: 01 December 2011, 16:05 »
Yes there is.
Where all my moneys went.
Offline dom
  • Back in a Mk4
Re: Bonnet Dampers
« Reply #4 on: 01 December 2011, 16:56 »
Yes there is.
Well I'd love to know how you propose he fits a nut without removing the wing :rolleyes:
When I fitted mine they screwed into an existing hole in the wing, granted I used a washer but there was no need for a nut.
Offline Bellend
Re: Bonnet Dampers
« Reply #5 on: 01 December 2011, 18:45 »
Yes there is.
Please don't use the " :rolleyes:" when you clearly don't know what you're on about.  :rolleyes:
Ask Shady, read the thread he made.
You slot a 13mm spanner nut and washer under the wing where the  boot strut lines up. Unless you had some magical strut or put them on in a completely different place to the rest of the forum.
I will get a photo later. The 13mm nut and washer is EASY to fit. So don't worry about it, no need to pull the wing off.  :grin:
Offline dom
  • Back in a Mk4
Re: Bonnet Dampers
« Reply #6 on: 01 December 2011, 19:01 »
Pot, kettle, black :lipsrsealed:
Mine screwed in without the need for a nut, the bolts were the correct size for the hole:
But seeing as I clearly don't know what I'm talking about, despite doing it to both the Mk3's I've had, I'll leave you to go back to being the be-all and end-all of Mk3 related gobsh!te.
Offline Bellend
Re: Bonnet Dampers
« Reply #7 on: 01 December 2011, 19:30 »
They're bonnet struts.  Not boot struts you advised to use. They ARE different. Boot struts need nuts. I'd imagine the OPs items are the same.
As you were.
Offline dom
  • Back in a Mk4
Re: Bonnet Dampers
« Reply #8 on: 01 December 2011, 19:44 »
As you were.
We'll wait and see.....
Hi,
 :lipsrsealed: :lipsrsealed:
Offline Bellend
Re: Bonnet Dampers
« Reply #9 on: 01 December 2011, 19:48 »
Which is the comment I've based my posts on. :)
