Author Topic: wheel bolts  (Read 1774 times)
Offline benvictors
  • bgk Tuning - coming soon!!!
Re: wheel bolts
« Reply #10 on: 30 November 2011, 23:07 »
What car you got mate, the bolt thread will be either M12 x 1.5mm Pitch Or M14 x 1.5mm Pitch, the length is normally the length of the thread, not the entire bolt  :cool:
The reason for fouling on the back of the hub is probably due to the Chamfered (cone) style bolts sit further into the wheel than the Radius style bolts. Are the wheels definately the cone style hole, drop one of the bolts inside the wheel and press it firmly in, there should be minimal or no movement left to right on the bolt when its seated properly, If the cone style bolt wobbles about a bit then try the radius one in the same hole just to be sure  :wink:
Offline Cory
Re: wheel bolts
« Reply #11 on: 30 November 2011, 23:15 »
yeah, they are defiantly the right bolts for the wheels. had a check before fitting. regret buying these lenso's more every day . . .  :lipsrsealed:
Offline Cory
Re: wheel bolts
« Reply #12 on: 01 December 2011, 01:29 »
wouldnt be worth it . . .
