Author Topic: steering is way off!!help!  (Read 1411 times)
Offline swinie
« on: 06 May 2005, 16:02 »
hey all,
got the car back from the garage and they did a few things to it, mainly the brakes, but they also changed one tyre and the ball joints. now i only got it back yesterday and the steering feels like its all over the place. to go straight i have to hold the steering wheel at about 45 degrees and its light turning one way and not the other (im sure thats because of the new tyre). any ideas as to why the steering wheel is off centre?im worried that the wheels arent lined up properly, but if they are and thats all fine can i just take the steering wheel off and put it back on at a slightly different angle?
what dya rekon?
thanks all
mike
Offline tinman
Re: steering is way off!!help!
« Reply #1 on: 06 May 2005, 16:04 »
Get the car tracked properly. Taking the steering wheel off isn't the answer usually.
Also, buy a new tyre for the other side. I have never bought single tyres, always buy in pairs unless you've just damaged a new tyre.
Offline tobz.
« Reply #2 on: 06 May 2005, 16:23 »
I'm always bleating on about it but if your ball joints have been replaced you should get your camber re-checked aswell. That could cause the light steering in one direction as there may be different areas of tyre in contact with the road on each side.
You got any pics of your dad's split ?
Offline swinie
« Reply #3 on: 09 May 2005, 17:24 »
thanks guys,
thats what i thought but its good to check incase im goin down the motorway and a wheel suddenly pops off!!
mike
Offline the_GTI_new_guy
« Reply #4 on: 09 May 2005, 19:55 »
thanks guys,
mike
Give your nuts a good yank just incase. Dont forget to fix the car either.  :laugh: Sorry, old joke but someone had to say it with a quote like that.  :wink:
Offline jettaTx
  • Mk1 16v + Mk2 G60 + 309 Goodwood Mi16 + Jetta 16v!
« Reply #5 on: 09 May 2005, 22:49 »
I am in the middle of havin mine fixed after having a clutch fitted left my set up in a similar state being off where perfect b4 the work began. It is the most frustration when things like this happen to your pride and joy but all ya can grin and bear it and get it fixed!!
 :grin:
Judderi
« Reply #6 on: 10 May 2005, 11:48 »
Id take it back to the garage as something isnt right!
