Author Topic: Wheel fitting advice  (Read 2072 times)
Offline dazzawest1987
« on: 29 November 2011, 21:14 »
Hi all really quick question, will 4x100 pcd alloys fit a 4x98 pcd hub with wobble bolts?
Cheers in advance
Offline justalex81
Re: Wheel fitting advice
« Reply #1 on: 29 November 2011, 21:16 »
should do
« Reply #2 on: 29 November 2011, 21:49 »
Cheers mate  :smiley:
Offline Jack3559
« Reply #3 on: 29 November 2011, 22:17 »
Has someone bought an Alfa?
« Reply #4 on: 29 November 2011, 23:04 »
nah mate, a mate at work has bought a lancia delta and he's looking for a set of multi spokes, found a set for him off a golf or polo, wanted to see if they're a feasible fit without a couple of hundred quids worth of adaptors
Offline mcgee9t2
« Reply #5 on: 29 November 2011, 23:20 »
wobble bolts should be fine for 2-3mill
« Reply #6 on: 30 November 2011, 09:32 »
Wobble bolts allow 2mm of adjustment but check the center bore size as well.
Offline lewis1641
  • stuck in the 90's
« Reply #7 on: 30 November 2011, 10:28 »
delta centre bore is 1mm bigger than vw. if the wheels are aftermarket chances are they have spigot rings that can be knocked out, if not they will need machining.
delta is supposed to be et40, chances are the vw wheels are 35. not cure how sensitive the lancias are to offset changes but i would imagine 5mm wont cause arch issues
Offline dvvid1993
« Reply #8 on: 10 December 2011, 19:55 »
wobble bolts will work fine they are good for 2.5-4mm usually
