Author Topic: golf gti mark 6 Daytime Running Lights  (Read 5306 times)
Offline jomo56
« on: 29 November 2011, 11:41 »
Can someone kindly tell me how I can deactivate DRL's. I live in France and can't understand the user's manual! Thanks
« Last Edit: 29 November 2011, 13:19 by jomo56 »
Offline EyeballPaul
Re: golf gti mark 6 Daytime Running Lights
« Reply #1 on: 29 November 2011, 14:46 »
I searched for it on here, but you have to
ignition off
Ensure lights are in off (0) position
indicate left and hold lever back to flash
turn ignition on and wait for some confirmation tones,
im about to try this myself cant take the sh** yellow DRLs anymore, aparantly you can only do it this way on a pre 2011 car with Halogens, otherwise you need to do it on the computer.
to switch them back on is the same process but indicate right
Offline jomo56
« Reply #2 on: 29 November 2011, 16:22 »
Thanks for that but what do you mean hold lever back to flash? Do you mean push indicator lever away? Appreciate your help!
Offline Neil gti
« Reply #3 on: 29 November 2011, 16:35 »
Pull the lever towards you as if you are going to flash someone, but hold it towards you until you get the confirmation tone  :smiley:
Mk6 Gti Gone but not forgtten
Loving the 7R
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #4 on: 29 November 2011, 16:52 »
Or it's in the settings menu on the DIS on the later ones  :wink:
Offline EyeballPaul
« Reply #5 on: 01 December 2011, 13:55 »
I just deactivated my DRL's, although it states everywhere including the manual, to indicate left to deactivate mine did not work.
I did the same process but indicated right and it worked.
Offline Keithuk
« Reply #6 on: 01 December 2011, 14:32 »
Welcome to the forum Jomo.
You don't state the year of your GTI as with 2011 and later you can't disable the DRLs manually as shown here you need someone with VAG-COM\VCDS.
What they are saying on here is.
DRLs OFF
1) Headlight switch to OFF (0),
2) Select Left indicator while
3) Simultaneously pull the indicator stalk back towards you to flash the lights while
4) Turning ignition ON on for a couple seconds - until you hear the DING.
DRLs are now OFF.
DRLs ON
2) Select Right indicator while
DRLs are now ON
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline dubber36
« Reply #7 on: 01 December 2011, 14:56 »
I thought on later cars, you had a DRL on or off option in the lighting section of the DIS.
Offline EyeballPaul
« Reply #8 on: 01 December 2011, 15:15 »
from what i can gather 2009 cars use the indicator stalk, 2010 cars use the DIS and 2011 can only be done through VCDS
Offline dubber36
« Reply #9 on: 01 December 2011, 15:29 »
Mines a Jan 2010, and that uses the indicator stalk.
