Author Topic: Launch Control on DSG Golf R?  (Read 14539 times)
Offline jdjd
« on: 28 November 2011, 17:20 »
How do I launch from a standing start with a DSG gearbox? Somebody with DSG please explain this for me thanks
Offline dubber36
Re: Launch Control on DSG Golf R?
« Reply #1 on: 28 November 2011, 17:34 »
Lever into "S"
Left foot on the brake
Right foot flat on the throttle (revs will hold at the optimum point)
Left foot off the brake
Hold on tight.
Offline jdjd
« Reply #2 on: 28 November 2011, 17:35 »
Cheers mate ill be trying this soon as i go out later  :evil:
ESP off I assume?
« Last Edit: 28 November 2011, 17:40 by jdjd »
Offline PenguinGTI
« Reply #3 on: 28 November 2011, 17:39 »
I'm basing this on the 6-speed DSG transmission in my Mk6 GTI DSG. (As far as I am aware only the 6 Speed DSG gearboxes have Launch Control, the 7 speed versions don't  :sad:)
But, to use Launch Control:
NB: In my experience the car prevents you using launch control if the car is not warmed up properly, so make sure you've warmed up the car.
1. Bring the vehicle to a complete stop with the engine running.
2. Hold the vehicle stationary with light pressure on the brake pedal.
3. Select either "S" or "+/-" modes with the gear selector.
4. Turn off the Traction Control (usually need to hold the TCS button for a second or two)
5. Press firmly on the brake pedal.
6. Fully depress the throttle. (The revs will be limited to 4000rpm if the car is standard. Some tuners can raise the launch rpms with software.)
7. When ready, release the brake pedal and the car will launch.
With the AWD you shouldn't have any worries about traction. Because it's an issue for the FWD cars, you'll find posts online suggesting to launch about 2500-2750rpm. In the R, you should be fine launching it at the maximum rpm available (ie. 4000rpm in a standard car).
Offline dubber36
« Reply #4 on: 28 November 2011, 17:53 »
Oops. I forgot about the ESP.
I had it turned off when I tried the Polo Match DSG courtesy car I had the other week, but it didn't work. I guess that's because it's a seven speed.
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #5 on: 28 November 2011, 18:17 »
Stop in "p"
Turn ESP off by pressing button for a few seconds
Left foot on brake (and keep it there)
Select "s" or "1"
Right foot gass pedal to full
Release brake to launch
Jimmymature
« Reply #6 on: 28 November 2011, 18:20 »
Remember, unless the engine is at the correct temperature it won't work.
Jim
Offline Steve30
  • Ed30 .
« Reply #7 on: 28 November 2011, 22:21 »
http://youtu.be/1S3t6EDmBMk
this might help  :drool:
Tiguan quicker than the Golf
Offline p3eps
« Reply #8 on: 01 December 2011, 22:37 »
I did tried it once after I completed my 1000 mile run in.
I had my VagCom plugged in, which times the 0-60.
Once day I'd like to try it again now that the car has done over 10000 miles and loosened off a bit.
Anyway... Here's the screenshot...
Golf R... 3 door, DSG, Leather, Reflex Silver, Black 19" Talladega Wheels, ACC, Parking Sensors, RNS510 with Dynaudio, Reverse Camera, Luxury Pack, Cruise Control & Fiscon Bluetooth.
Offline The Doc
« Reply #9 on: 01 December 2011, 23:38 »
Nice - I'd like to see how that compares vs my race logic timing gear, I smell a test coming on  :wink:
