Author Topic: Fitted a td engine and wount crank over  (Read 4463 times)
Offline Mann
« on: 27 November 2011, 12:05 »
I have finished td coverstion on golf driver. I have plugged alll wires on engine primed the diestel fuel. when I try start it wount crank and I look glowplug amber light go off very quickly, normally light on for 5 sec then go. When I take key off dash light still on!? What I have missed?
Engine and looms is from 1986 and fitted in 1991 golf driver. Engine code is JR
can anyone come with answers?
 :drool:
Offline clipperjay
Re: Fitted a td engine and wount crank over
« Reply #1 on: 27 November 2011, 12:14 »
Jeez man it could be anything not much to go on TBH I say ECU, fuel, electrics take your pick
I think more infomation is need mate
What TD engine was fitted?
What conversion method did you use?
What YOU actually did?
What is working for sure etc....
I'm lost on this completely if you are expecting an answer from me!
But hey cool you have done this where is the project page?  :cool:
Offline danny_p
« Reply #2 on: 27 November 2011, 13:05 »
an 1986 loom dosent plug into a 1991 car without adjustments  as the later car is ce2 not ce1 like the loom
all the VW's have gone bar 1.
Offline Mann
« Reply #3 on: 27 November 2011, 13:20 »
Everthing is workig i.e wipers, rear lights etc just need engine to fire up.
It dones't have ecu as it td not tdi.
I will put on project page when my golf is 100%
Offline clipperjay
« Reply #4 on: 27 November 2011, 13:23 »
You understand its hard to see what is wrong without more information mate?
So TD is from a Jetta? GTD?
Offline Mann
« Reply #5 on: 27 November 2011, 13:25 »
yes I use ce1 loom and fusebox and rear light wire is the same as ce2 so I plug togher, everything is working i.e wiper, lights. Only need to fire up engine. It is turbo diestel not petrol engine.
Glow plug and all red light dial disappear very quickly when I turn on key.
Offline Mann
« Reply #6 on: 27 November 2011, 13:26 »
oh sorry, td engine from 1986 golf cl td and i put it in 1991 golf driver but i took off ce2 loom and fit ce1 loom for engine.
Offline clipperjay
« Reply #7 on: 27 November 2011, 13:28 »
Engine worked fine before transplant?
What about fuel lines and fuel filter all swapped over correctly?
Offline Mann
« Reply #8 on: 27 November 2011, 13:32 »
Yes before i start engine before I took off. I put a td fuel tank on golf driver all pipe connected and diestel fuel go in fuel filer and go in pump.
Offline clipperjay
« Reply #9 on: 27 November 2011, 13:49 »
So it doesn't turn over now at all?
I would start by checking voltages to the starter first then take out the plugs to check if they are defo working!
Its sounding more electrical issues to me if everything primes.
I know it takes a long time to get fuel in chamber if its lost vacumn in the lines!
But if ignition does nothing you will have to trace the battery to starter to ignition.
In theory diesels should be easier to start than petrol!
Have you tried Bum starting it i.e roll down hill then crank it?
