Author Topic: Mk2 16V interior questions - with pics!  (Read 9741 times)
Offline mad4vws
Re: Mk2 16V interior questions - with pics!
« Reply #10 on: 28 November 2011, 18:25 »
i have the matching door card front and rear to match the rear bench ,did have the seats but sold the passenger 1 as the drivers was worn as they normal do .
if you want the matching door-cards drop me a pm mate. :laugh: :smiley:
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!!  ON 07813936583
Offline mad4vws
« Reply #11 on: 28 November 2011, 21:34 »
ps  your car must look odd with different door card and rear bench and carrodo  front seats . :undecided: :laugh:  :smiley:
BREAKING VW GOLF'S
Offline Neo Badness
  • Feet are for pedals
« Reply #12 on: 29 November 2011, 00:18 »
Those are Driver door cards (yellow with blue). Used to have identical ones in mine before I re trimmed them.
Beat me to it with the Corrado seats. TBH corrado seats are arguably more comfortable than golf ones as the bases are longer. Also they sit lower as they are for the low roof coupe. Could always avoid the pain of tracking down a replacement golf interior and get them trimmed up to match?
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #13 on: 29 November 2011, 17:13 »
Those door cards also come out of Early GTI's they did do a checked patterned the same as the one pictured with the blue & yellow stripping...
I broke a car with them in ages ago...
For More Info Click To See;
Offline dubber36
« Reply #14 on: 29 November 2011, 17:34 »
So if it is a very late 16V, should it have Rainbow, or Ultra Violet?
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #15 on: 29 November 2011, 17:37 »
I think UV's were only fitted to BBM & White cars AFAIK..
I thought all other coloured Late 16V had Rainbows, but I guess it depended on what the buyer or dealership ordered...
Offline dubber36
« Reply #16 on: 29 November 2011, 18:00 »
Just translated the data sticker, but that doesn't tell us anything.
3FB = Spoiler roof
5J1 = Rear spoiler
4KC = Side and rear windows in heat-insulatingglass
4CF = code not found :-(
3MB = Velveted fleece floor covering
8J1 = Hand brake/low brake fluid level warninglight without inscription
8K2 = Daytime driving light mode for urban driving
8M1 = Rear window wiper and washer system with intermittent control
3D1 = Center console
8TD = Rear fog light for driving on the left
8WD = Integrated front fog light
SW0 = Body delivery from Ingolstadt plant to Brussels plant
1TB = Fuel tank vent line with gravity valve and PVC breather hose
1H1 = Load-sensitive proportioning valve
X2B = National sales program Great Britain
1AF = Power brake
1ME = Steering wheel
8BK = Twin headlight for driving on the left, with integrated high beam
8F2 = Side turn signal lights
Offline jonno74
« Reply #17 on: 01 December 2011, 18:53 »
Thanks for the replies and good info! I definitely need to loose the yellow/blue stripe cards , nasty against the red paint. :sick:
Re-trimming the fronts could be a viable option , the Corrado seats do the job well - any ideas on cost?
cheers
Offline Neo Badness
« Reply #18 on: 01 December 2011, 19:35 »
cheers
Too many factors, like who you use to the type of material. 350- to 3500, sure someone local to recommend. Although if you fancy a bash yourself you can achieve good results with a bit of patience and decent glue :wink:
Offline mad4vws
« Reply #19 on: 01 December 2011, 20:06 »
These are  not Driver door cards (yellow with blue). they are out of a gti same as mine they are early gti from 'e'1988 on ward then they made the red/black and white trim up to 89/90 then the rainbow trim was used. :smug: :wink: :smiley:
BREAKING VW GOLF'S
