Author Topic: 16v splutter when headlights turned on  (Read 1705 times)
Offline neville bartoz
« on: 26 November 2011, 18:26 »
Hi all
As above, a friends 16v mk2 has recently started to intermittently splutter when you turn the headlights on and you leave it to idle or back off the throttle. As soon as you turn the headlights off no problems. Any ideas?
Previous to this, the fuel pump fuse has melted(not blown) but this happens rarely and has been fine for a couple of months.
Thanks Mark
Offline mk2bal
Re: 16v splutter when headlights turned on
« Reply #1 on: 26 November 2011, 21:31 »
Y'alright there nev? Its uncle chop chop here.. I see you're flyin mate f'in flyin
Offline weazgti
« Reply #2 on: 26 November 2011, 23:13 »
lol :grin:
Offline weazgti
« Reply #3 on: 26 November 2011, 23:24 »
I had this on mine. Found it was the ignition module at fault by moving off where its screwed down while it was running. If I moved ecu cage it would spark at the base of the cage and not run, sounds daft I know but it all happened after I messed about in that area. I know yours hasnt got an ecu there but it still has the cage with the amplifeir on it. Worth trying for the sake of 2 screws.
Couldn drive at night in mine because as soon as I put lights on it made the car rough.
« Reply #4 on: 01 December 2011, 14:46 »
 aint got any money for you chop chop.
We've have had a lot of problems with that particular part in the past. Will give that a try on the weekend.
