Author Topic: Wheel spacers + bolts on mk4 golf  (Read 6039 times)
Offline SM-25
« on: 26 November 2011, 18:12 »
New to this but need help so decided to make an account (glad i have now) ;)
I've just put FK coilovers on my mk4 golf and then 18'' rs8 alloys.. They look brilliant apart from the gap between the spring and the tyre which is 1-2mm :/ im worried about this rubbing when having a full car so decided to get wheel spacers.. But which size? And will i need to buy some longer bolts? Not really fussed if its flush or not but any help/advice is appreciated. Cheers :-)
Offline mcgee9t2
Re: Wheel spacers + bolts on mk4 golf
« Reply #1 on: 26 November 2011, 18:14 »
ide got twenty on the back ten on front. and yes you will need longer bolts.
Offline daz veedub
  • Operation 1.8t bolf
« Reply #2 on: 26 November 2011, 18:27 »
20mm on rear and lowered took paint off my arches, also on 18s
Offline SM-25
« Reply #3 on: 26 November 2011, 18:32 »
Ok cheers mate what lenght bolts did you get and did you have to cut them down?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 26 November 2011, 18:33 »
15mm on the back 5mm on the front for me  :smiley:
Offline cullygti
« Reply #5 on: 26 November 2011, 19:01 »
same as wazzer for me to but feel i need to raise my coilies a little as im getting stuck on them bloody speed bumps  :laugh:
Offline mcgee9t2
« Reply #6 on: 26 November 2011, 19:16 »
shouldnt need to cut them down, just get the standard sized bolts but then add on the size of the spacer, cant remember what the standard bolt size is but im sure someone like wazzer will know.
Offline daz veedub
« Reply #7 on: 26 November 2011, 19:29 »
if u buy hubcntric spacers most of the time longer bolts come part of the package
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 26 November 2011, 19:33 »
my rear spacers are bolt on so I had to cut the bolts down to fit. They are 28mm long apparently so just add the width of your spacers to that to get the bolt size you need. 5mm or lower width spacers can be fitted without getting longer bolts
Offline Steve_PD
« Reply #9 on: 26 November 2011, 20:23 »
Id fit longer bolts with every spacer.
When I had 5mm fitted to my car the original bolts only went in 4 threads or about 5mm.
