Author Topic: dizzy and leads  (Read 1732 times)
Offline gti gaz
dizzy and leads
« on: 25 November 2011, 21:06 »
best place to purchase uprated dizzy and leads for 8v any ideas want to shop around
 Any one in cornwall lets sort more meets!!!!
Offline Seanl
Re: dizzy and leads
« Reply #1 on: 25 November 2011, 21:20 »
I honestly wouldnt worry about 'uprated leads'. Standard 7mm leads are all that you need, and any bigger will not make a blind bit of difference in the real world (apart to you bank account). Just get OE spec ones from GSF/ECP etc..... At least you know they will be decent quality, and have a proper warranty in comparison the the multitude of colour uprated 8mm stronger spark and better detonation blah blah blah sh!te you will see on ebay, that corrode and break down within a year!
Offline Ess_Three
Re: dizzy and leads
« Reply #2 on: 25 November 2011, 21:21 »
You won't get any extra power from leads or a dizzy...so unless you want pretty looking leads (which are often cheap tat) I'd suggest a set of VW/Beru leads.
This lot are as good as any : www.vwspares.co.uk
..but gaining motorcycles.
Offline Ess_Three
Re: dizzy and leads
« Reply #3 on: 25 November 2011, 21:22 »
^^^ What  he said  :grin:
Offline gti gaz
Re: dizzy and leads
« Reply #4 on: 25 November 2011, 21:28 »
ha ha chears got me a 5k limit the other day and only just replaced rotor,dizzy and leads so thought about uprated ones cos the ones i got from mill auto were proper sh!t might try gsf always forget about them thanks again
Offline Ess_Three
Re: dizzy and leads
« Reply #5 on: 25 November 2011, 21:38 »
Check what gsf sells...some OEM makes are better than others...Beru makes the VW stuff I believe, so if you can get Beru, get it.
Re: dizzy and leads
« Reply #6 on: 25 November 2011, 23:52 »
Or Bosch if you can find it  :smiley: just avoid cheap tat
