Author Topic: Carbonio install help  (Read 1406 times)
Offline leericho
« on: 25 November 2011, 20:34 »
Just got hold of a carbonio intake for my mk4, there's no instructions with it! Obviously the filter sits in the wheel arch, swell as the filter there's an aluminium 90 degree pipe and the carbon pipe, what goes where? Do I need anything else??
All help appreciated hope to pop it on tomorro
Cheers Lee
Offline tonysgti
Re: Carbonio install help
« Reply #1 on: 25 November 2011, 20:55 »
do u have the silcone join from the maf to the carbon pipe?
Offline leericho
« Reply #2 on: 25 November 2011, 21:04 »
No, what size is that?? Diameter and length? Any ideas??
Cheers Lee
Offline Phil18t
« Reply #3 on: 01 December 2011, 20:47 »
the pipe he means is the reducer/join pipe from the maf to the carbonio bowt 3"long and is stepped, wen u have your airbox and intake removed you will see below the back of ur headlight theres a hole down to behind your bumper, thats where the bent alu pipe goes..quite fiddly to fit.
Offline leericho
« Reply #4 on: 04 December 2011, 11:21 »
yes thats the one!! i think its 75 down to 70mm, does that sound about right?  :undecided:
cheers Lee
