Author Topic: Warranty on milltek systems  (Read 2075 times)
Offline shaft69
« on: 25 November 2011, 18:03 »
Checking under mine tonight a work, found at rear box welding split near all way round and blowing . Still got bill £740 full system inc APR d/p with sports cat from awesome. bought april 2009 do i get onto milltek or awesomegti??
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Warranty on milltek systems
« Reply #1 on: 25 November 2011, 18:11 »
Will be manufacturers warranty so Miltek :wink:
Offline Chris.
« Reply #2 on: 25 November 2011, 21:11 »
WArranty only for a year though.
Warranty doesnt cover bad workmanship.
Play unhappy with milltek.  Its a common problem.
Click For Build Thread
Offline harlemex
« Reply #3 on: 25 November 2011, 21:51 »
when you say bad workmanship, are you referring to whoever fitted the exhaust?
Offline Chris.
« Reply #4 on: 25 November 2011, 21:52 »
Nope - quality of the welds!
Offline shaft69
« Reply #5 on: 25 November 2011, 21:53 »
Not back workmanship weld broken, exh itself fitted perfect.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline sprout99
« Reply #6 on: 25 November 2011, 22:18 »
did you send off warranty card?
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline sivrs
« Reply #7 on: 25 November 2011, 22:23 »
Thought it was a lifetime guarantee but only valid  for the person who actually brought the exhaust new?
I could be wrong tho  :smiley:
Offline james2
  • No scammers please.
« Reply #8 on: 25 November 2011, 22:35 »
+1 ^ i think
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Steve_PD
« Reply #9 on: 25 November 2011, 22:36 »
It is bad workmanship for the welder who welded it
This
