Author Topic: MOT went well :) Quick question on anti roll links  (Read 772 times)
billabong
« on: 25 November 2011, 15:39 »
MOT went considerably well today..
Only two advisories:
Slight play in anti roll bar link on Nearside
Slight play in rear wheel bearing
Picked up a new rear bearing on the way home, I've done these before so shouldnt be a problem. How easy are the Anti roll bar links to do?
Offline neil_1821
Re: MOT went well :) Quick question on anti roll links
« Reply #1 on: 25 November 2011, 23:51 »
Ah same advisories my MK3 got
I wouldn't of said you needed a new wheel bearing, the rears you are able to tighten to take the slack out of them, which is something i've still to do
Anti roll bar links are really easy, although sometimes the bolts are rusted in place so it's best to whip them out because if their buggered you'll have to goto a motor factors and get 2 new bolts, once their out they are really simple
« Reply #2 on: 25 November 2011, 23:53 »
As above you should be able to adjust the wheel bearing.
Offline javalin
« Reply #3 on: 28 November 2011, 09:15 »
but be careful - they are supposed to have a slight play - if its the ones with a split pin in them at least.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
