Author Topic: battery question?  (Read 1692 times)
Offline sps
battery question?
« on: 25 November 2011, 15:37 »
the car is a mark 3 vw golf 1.4gl -1996 model.
the existing battery is either a 40Ah or 45Ah capacity.
would it be ok to fit a 70Ah battery which is coming from  2004 vw bora diesel car ?
also would the golf alternator be able to charge this higher spec battery?
Re: battery question?
« Reply #1 on: 25 November 2011, 23:55 »
Unless you really need the bigger battery I would stick with the standard size.
Offline sps
« Reply #2 on: 26 November 2011, 10:27 »
ok, but this is the key question is-"also would the golf alternator be able to charge this higher spec battery?"
« Last Edit: 26 November 2011, 12:33 by sps »
Offline Bellend
« Reply #3 on: 26 November 2011, 12:15 »
Mines been running a HUGE T4 battery for months. Been spot on.
Where all my moneys went.
Offline sps
« Reply #4 on: 26 November 2011, 19:10 »
thanks,we fiited it into the golf this afternoon.
the alternator is a bosch one and the tag on it says 14v and 70a-so the 70 ah battery fitted straight in.
Car starts up fine,so should charge up fine.
« Last Edit: 27 November 2011, 10:09 by sps »
« Reply #5 on: 26 November 2011, 21:53 »
the alternator is bosch one andand istamped with 14v and 70a-so the 70 ah battery fitted straight in
car starts up fine,so should chargeup fine.
Might be better to switch to a 90amp alternator.
Offline DubAndDubber
« Reply #6 on: 26 November 2011, 23:43 »
a higher battery is fine, no need to change anything. just dont go lower!
Mk5 Golf Gti 06'
