Author Topic: boost pressure valve mechanical fault / anyone had this ???  (Read 1193 times)
Offline connn12
as above recently plugged on and managment ight on for reason : boost pressure valve mechanical fault anyone had this before ? cheers
Offline Granta Gti
Re: boost pressure valve mechanical fault / anyone had this ???
« Reply #1 on: 25 November 2011, 07:01 »
Never had that. Sounds like the N75 valve. I would clear it and see if it comes up again
Offline daz veedub
  • Operation 1.8t bolf
« Reply #2 on: 25 November 2011, 12:44 »
yeah delete code and see if comes back, are u having any boost issues  :undecided:
jamie16v
« Reply #3 on: 25 November 2011, 16:50 »
dergubugle or pekratol?
Offline harlemex
« Reply #4 on: 25 November 2011, 21:57 »
pekratol I think.
Offline Chris.
« Reply #5 on: 25 November 2011, 21:58 »
Either way, do a log of the N75 valve duty cycle and see what its doing.  Will give the best indication IMHO.
Click For Build Thread
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 26 November 2011, 00:32 »
i would say your diverter valve is broken. check that first
Offline connn12
« Reply #7 on: 27 November 2011, 10:47 »
Hi all cheers for ya help right answers
1. deleted code came back on
2. I don't think it's boosting right at all
3. Rolling roaded it n was 112 at the wheels should be more shouldn't it !
4. Just ordered boost pressure valve from work what these other things you think could be ? Cheers con
« Last Edit: 27 November 2011, 10:50 by connn12 »
