Author Topic: front flange o ring thing.... easy one..  (Read 5681 times)
Offline Guy
« on: 23 November 2011, 22:45 »
right chaps
a friend of mine contacted me about the mk3 8v I sold to them a while back saying it was overheating this morning
obviously in the 8k miles they have had it they haven't looked under the bonnet or checked levels once!!  :grin:
went over this evening... no coolant in the reservoir
suspicious amount of fresh fluid in the engine bay
signs of leakage around a flange area where the front of the block meets coolant pipes, it has some kind of temperature sender mounted on the top I think
took the flange off and the O ring was knackered
questions...
what is this 'flange' part called... can anyone give me a GSF part number for it, roughly how much do they cost
Untitled by Guy Frankland, on Flickr
i will be getting a new O ring for it anyway as this one is completely shot
do you guys think it is worth replacing the whole flange assembly?
will replace part if suggested on here, def replace O ring, drain and refill coolant with G12 plus plus - any other suggestions?
Offline CJA321
Re: front flange o ring thing.... easy one..
« Reply #1 on: 23 November 2011, 23:13 »
When i did my headgasket on my 8v  just got the o ring with the headset. but the new o ring leaked abd leaked.... took a tub of radweld to sort it lol.
I THINK thats the thermostat housing/temp sensor.
try an o ring with a bit of sealant on it as well. youl soon see it leaking if it dosnt work.
cheapest option first!!  :wink:
Offline dragongreengolfgti
  • my golf gti mk3
« Reply #2 on: 23 November 2011, 23:21 »
For piece of mind over winter if your changing the coolant already i would by a complete unit which are about £15 and come with the correct o ring  :smiley: can either get them from vw/gsf/  or even ebay use gasket sealer on there also. Another thing is i would put a new thermostat and housing down the bottom aswell as these parts are also cheap and as like last year on my old 8v just as winter was kicking in thermostat decided to break  :cry: hope you sort it out  :smiley: might even be worth chucking a new temp sender in there also as that can make all kinds of running issues and i think there about £10
« Reply #3 on: 23 November 2011, 23:39 »
Pick up a genuine flange and o ring, not that expensive and worth it in the long run.
VW BUSH
« Reply #4 on: 24 November 2011, 00:15 »
Rub the block down with a hard stone or the like until its clean, flat and free of scale.
Genuine VW £20 + Vat, ECP £15 (Make sure you get blanking plug and seal)
Use O ring grease so seal is free to move and dont over tighten.
Easy.
I'd go with Wayne on a genuine part if you can.
Offline Guy
« Reply #5 on: 24 November 2011, 08:49 »
so we're calling it a headset flange and O ring?  :laugh:
(sorry can't help laughing every time a part is called something silly)
will get
  • Genuine flange and O ring from VW - need to pick up some G12++ from there anyway
  • blanking plate
  • O ring grease (where from - halfrods?) Would normal grease do?
i replaced thermostat and temp sender when I had the car so I know they're in good nick (one would hope so anyway)
please advise if there is anything else I need to do :)
:afro:
« Reply #6 on: 24 November 2011, 09:19 »
I have never used o ring grease always fitted them dry, guessing yours was an AGG.  :smiley:
1: 037121132E flange with sealing ring
9: 357121140 plug
10: N 90316802 round seal
11: 032121142 retaining spring
5: 037121687 seal
Offline Guy
« Reply #7 on: 24 November 2011, 12:44 »
thanks Wayne... just hunting about for the part at the moment... VW Reading don't have it!
Offline javalin
« Reply #8 on: 24 November 2011, 14:51 »
most mk3 parts are next-day order.
J
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Guy
« Reply #9 on: 24 November 2011, 17:02 »
Martins VW Camberley came up trumps in the end... popped over and picked everything up
£25 for this lot
9: 357121140 plug
5: 037121687 seal
and some G12++ and 20% for mr tax man..
not bad considering...
so took it all apart, put it all back together, drained it, filled it, ran it, drove it
jobs a goodun  :smiley:
thanks one and all for your help :)
