Author Topic: cab lights on standard shape mk1....  (Read 1662 times)
Offline Optimus Wol
  • Theres an evil monkey in my closet......
« on: 05 May 2005, 11:55 »
whats involved putting the rear lights from a cab onto a normal mk1? is it just a straight swap??  :huh:
Offline gibby
Re: cab lights on standard shape mk1....
« Reply #1 on: 05 May 2005, 12:22 »
I'm pretty sure that they wont fit as they are different sizes I think.  :undecided: Have a look at some of the styling companies and see if they sell different ones for cabby's and tintops, if they do then they are deffo different sizes.  :smiley:
« Last Edit: 05 May 2005, 12:33 by gibby »
......now officially dubless.
Offline 10:27
« Reply #2 on: 05 May 2005, 13:58 »
i think they will fit a small rear light mk 1 but not the bigger rear light mk 1 hope this helps
Offline richard ellison
  • Mk1 Cab 'Gertrude'
« Reply #3 on: 05 May 2005, 14:08 »
nope different sizes. the mk1s tintops are longer thinner lights...
Offline Phil303
« Reply #4 on: 08 May 2005, 10:02 »
It's only the later MK1 tintops that had the larger lights, the earlier ones do have the same cluster as the Cabrios.
The larger lights came in from 1981 onwards (and were actually closer to what the golf designer, Guigaro, always intended them to look like, fact fans!).
Offline BobbyT
« Reply #5 on: 12 May 2005, 11:19 »
yeah mine is an 82 and has the longer lights, maybe you could fit the cab ones with a bit of fetterling and fill the holes left by the longer lights?? :huh: :tongue:
Offline Optimus Wol
« Reply #6 on: 12 May 2005, 11:54 »
looks like some tinkering is in order then!! i'll let you know how i get on if i ever try.................
