Author Topic: inner arb change advice.  (Read 2286 times)
Offline parky86
« on: 23 November 2011, 18:53 »
trying to change inner arb bushes on a gti but cant seem to get at them, is there any easy way to change them? as it looks like i have to drop the subframe which i don't really want to do.
Offline javalin
Re: inner arb change advice.
« Reply #1 on: 24 November 2011, 14:53 »
yes - you have to lower the subframe a bit.  At most about 1cm or so, else you pull the steering UJ appart - which is what I did.
Bit of a PITA to be honest.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline parky86
« Reply #2 on: 24 November 2011, 17:48 »
James
cheers mate glad i didnt try then! id probably end up doing the same think il just leave it for now!
