Author Topic: AGG Spark plugs  (Read 2882 times)
Offline geeksteve
AGG Spark plugs
« on: 23 November 2011, 13:27 »
Odd question... What should the top of the spark plugs look like on a 2.0 8v (AGG)? I've ordered some and they have an end like this:
But my existing ones have an end like this:
A quick browse online shows everyone seems to have the wider type (which means I was probably shipped the right stuff). So do I have some unusual after market ones? The HT leads *look* like the standard ones (i.e. long metal shroud etc)..
Any insight would be welcome, apologies if it's obvious and I'm being a 'tard ;)
S
Offline Len
Re: AGG Spark plugs
« Reply #1 on: 23 November 2011, 13:29 »
Screw on /screw off!
I actually suspect your existing ones are faulty but if not then you just unscrew the top cap of the plug.
www.sas.org.uk
www.the-ace.org.uk
Offline Seanl
Re: AGG Spark plugs
« Reply #2 on: 23 November 2011, 13:33 »
Yeah top ones look right. NGK BUR6ET iirc.
Offline gti gaz
Re: AGG Spark plugs
« Reply #3 on: 23 November 2011, 13:33 »
as above unscrew
 Any one in cornwall lets sort more meets!!!!
Offline geeksteve
Re: AGG Spark plugs
« Reply #4 on: 23 November 2011, 13:34 »
You can unscrew the top? Bugger me, never knew that. I'll have a look this evening, but I suspect it confirms my initial suspicion that I was just being a 'tard :P
Cheers..
Offline mad4vws
Re: AGG Spark plugs
« Reply #5 on: 23 November 2011, 14:19 »
You can unscrew the top off /on , btw the correct plugs are the 3 core or prongs one not single core. :smug: :cool: :smiley:
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!!  ON 07813936583
Offline javalin
Re: AGG Spark plugs
« Reply #6 on: 23 November 2011, 15:23 »
the quad prong bosch super plus work well too :-)
something similar to : http://www.ebay.co.uk/itm/1-PERORMANCE-UPGRADE-SPARK-PLUG-BOSCH-SUPER-4-VW-Golf-mk3-2-0-Cabriolet-97-/300606923588?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item45fd91a344
but get correct ones for your engine....!
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline geeksteve
Re: AGG Spark plugs
« Reply #7 on: 23 November 2011, 15:38 »
Heh, the current ones have one, replacements have 3 ;)
S
Offline bluquarta
Re: AGG Spark plugs
« Reply #8 on: 23 November 2011, 16:15 »
lol I had this exact issue the other day when I changed my HT leads. Had Beru plugs and Beru leads and couldn't work out why the fit was so bad. 10 mins later I remembered the top bit unscrews off the plugs.... like a glove  :grin:
