Author Topic: Audi A6 Allroad problems`  (Read 1366 times)
Offline TurboBeast
« on: 23 November 2011, 09:48 »
I was wondering whether any boffins can help here on this one, a chap at work has an Audi A6 All road, he has been having turbo issues etc etc and had sensors replaced and a new turbo etc.  When we did a handheld scanner read the car suggested fault codes:
00519 P0106 MAP Sensor - Out of Range -G71
00519 P0107 MAP Sensor - Voltage Low -G71
00519 P0108 MAP Sensor - Voltage High -G71
00532 P1746 Transmission Control Module Relay - Supply Voltage (B+) Malfunction Low
Battery or Bad Ground
00532 P1750 Supply Voltage (B+)
01119 Transmission Shift-Range Gear Position Signal
We cleared the three codes as we suspect 00532 and 01119 may be due to the battery being removed and ran the checks again, as the checks were redone Engine and ATS ran fine, No Codes however when we ran SRS, the car's adjustable suspension started adjusting making the car higher but no codes were found.  Then when we ran ABS three Times the Fuel light, brake light and triangle with a ! inside displayed and a beep sounded but again no codes reported.
Any ideas we are at a bit of a loss.
