Author Topic: R32 suspension...  (Read 1356 times)
Offline scarr89
  • Mk4 Golf, DERV FTW!
R32 suspension...
« on: 22 November 2011, 17:29 »
on a standard mk 4 (130PD), yay or nay? Does it fit if so how low will it sit, as I know you can buy say 40mm/60mm lowering springs etc but I do not know how 'low' the R32 suspension is compared to the standard on the 130.
Running 18's BTW  :smiley:
Offline Adam
Re: R32 suspension...
« Reply #1 on: 22 November 2011, 17:37 »
Fronts will fit but rears will not.
Down Hill From Here.
Offline scarr89
« Reply #2 on: 22 November 2011, 17:39 »
Ohhh really. Why is this may I ask?
Offline scarr89
« Reply #3 on: 22 November 2011, 17:42 »
I think I have just clocked why the rears won't. Is it cause the way it is bolted in top and bottom? as in not on an angle, just 2 bolts going through the strut?
Would it be ok to run say just the front shocks and springs and rear springs and then get some different rear shocks?
Offline dom
  • Back in a Mk4
« Reply #4 on: 22 November 2011, 17:48 »
I'm not sure the R32 rear springs will fit :undecided:
Offline scarr89
« Reply #5 on: 22 November 2011, 17:49 »
Ok, cheers guys.
Will source some other suspension  :smiley:
« Reply #6 on: 22 November 2011, 21:53 »
Ok, cheers guys.
Not going to work very well on the front due to difference in engine weight etc.
