Author Topic: HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!  (Read 6297 times)
Offline mk1
Re:HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
« Reply #20 on: 30 September 2003, 20:26 »
It is not easy to diagnose a fault remotely, I still think you have the original fault. As vr6 said prob a fuel fault, check the fuel pressure, try my "dont try this at home" test. If you have good spray, check for air leaks around the pipework from air flow meter to throttle body,esp the pleated rubber part. Good luck, Steve.
Offline richie2480
« Reply #21 on: 04 October 2003, 17:47 »
I have a mk2 16v K-jet too. I was in Germany at the time and I had a similar problem. I thought it was the fuel system but I took it to a VW garage. He diagnosed a faulty distributer and sure enough that is what it was.
