Author Topic: Head Gasket  (Read 2571 times)
Offline Golf mk4 reborn
Head Gasket
« on: 21 November 2011, 21:33 »
Hi,
I have a 2.0gti Golf w reg and my head gasket mixed and plus my springs are gone as well as my motor starter, and was just wondering if anyone had a idea was the cost would be to repair it and if its worth the hassle.
Thank you in advance
Offline Chris.
Re: Head Gasket
« Reply #1 on: 21 November 2011, 22:10 »
Parts probably about £100 for headgasket, bolts and a starter.
labour....anything up to £200 IMHO.
Click For Build Thread
Re: Head Gasket
« Reply #2 on: 21 November 2011, 23:44 »
Thank you so much I was thinking to throw the car away as the mechanic said it would cost £800
Re: Head Gasket
« Reply #3 on: 21 November 2011, 23:47 »
Are you 100% sure the head gasket is gone and not the oil cooler.
VW BUSH
Re: Head Gasket
« Reply #4 on: 21 November 2011, 23:51 »
You could have a whole new engine fitted for that price, shop around :smiley:
Re: Head Gasket
« Reply #5 on: 22 November 2011, 18:46 »
I think its my head Gasket cause, When i turn the car on it start giving me the stop sign and says check coolant, and my oil and water have mixed so I think my head gasket needs to be skimmed but to be honest this is my first golf and iv only had it for to weeks and hate VW already.
Is there anything in particular that I can do my self to find out exactly what's happened to the car?
Offline GeorgeyBoy
Re: Head Gasket
« Reply #6 on: 22 November 2011, 18:56 »
Compression test the cylinders. Cheap and easy for a tester. If you get two cylinders low on compression (usually should be around 12 psi) then probably leaking between the two. If just one them leaking elsewhere.
Definitely check the oil cooler though cause this can perish and cause the oil to mix with coolant. Which makes it look like the head gaskets gone.
Re: Head Gasket
« Reply #7 on: 22 November 2011, 19:13 »
Thank you for your help am gonna check that before I do change the head gasket, Your a genius
Re: Head Gasket
« Reply #8 on: 22 November 2011, 20:41 »
Bypass the cooler, drain and flush the cooling system through then run it for a day or so and see if it comes back.
Offline justalex81
Re: Head Gasket
« Reply #9 on: 23 November 2011, 19:27 »
300 quid to change a head gasket and starter motor. are you on crack?
