Golf mk4
Wazzzer
Standard airbox but with SAI removed
Topic: Standard airbox but with SAI removed (Read 1427 times)
Dalo Harkin
21 November 2011, 08:29 »
Does anyone run the standard airbox but has done the SAI removal?
what did you block the hole on the airbox with?
ARZ K03s, Oettinger Side Skirts, R32 front, Carbon stage 2, Forge 007p (yellow spring), Forge Actuator (yellow spring), Pipercross panel filter with DSG parts, N249 and N112 deleted, SAI deleted, Carbon canister deleted, Rear wiper deleted, Long Life turbo back custom exhaust with 200 cell sports cat, VR6/G60 clutch kit, Creation Motorsport TIP, Catch can, 'Wellycooler', K04 charge pipe, S3 ported inlet manifold - looks pretty standard on the outside though
jockgti
Guest
Re: Standard airbox but with SAI removed
21 November 2011, 09:06 »
I used a piece of plastic cut to size with some electrical tape holding it on
sivrs
GTI forum regular
21 November 2011, 09:19 »
I used black tape
Worked a treat
daz veedub
Forum addict
Operation 1.8t bolf
21 November 2011, 09:44 »
i run a cold air feed to my airbox
Dalo Harkin
21 November 2011, 12:20 »
Would rather block it with something permanently if i can, at the moment I just have a cone filter before the MAF, no induction pipe, but would like to go back to the airbox...
Cheers all
Imteyaz
21 November 2011, 19:42 »
I pushed (forced) on the black screw cap that was originally on my Synta Silver oil container - almost perfect fit!
sivrs
GTI forum regular
Reply #6 on:
21 November 2011, 19:45 »
Find some other old plastic and cut a circle to fit and then plastic weld it in or fibreglass fill and paint it
james2
No scammers please.
Reply #7 on:
21 November 2011, 22:31 »
i have a blue pipe and alloy thing / small fillter fits on if you want message me £5 posted 1st class.
http://www.ebay.co.uk/itm/VW-GOLF-MK4-1-8-20V-1999-2004-TURBO-BLUE-COLD-AIR-FILTER-INDUCTION-INTAKE-KIT-/220833102302?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item336aadb9de
I have agu i didnt use them.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Golf mk4
Wazzzer
