Author Topic: HELP.....mk2 compbrake adjustable top mounts ?  (Read 4913 times)
Offline adziboy
« on: 19 November 2011, 17:35 »
hello i need help how do you fit compbrake adjustable top mounts bought for my project of a mk2  and no instuctions please help  :sad:
Offline jv
  • Administrator
Re: HELP.....mk2 compbrake adjustable top mounts ?
« Reply #1 on: 25 November 2011, 14:05 »
The supplier no help?
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline Len
www.sas.org.uk
www.the-ace.org.uk
« Reply #3 on: 25 November 2011, 16:16 »
What problem are you having, they are easy to fit really, all the holes are for caster / camber adjustment as required.
VeeDubGTI16v
« Reply #4 on: 26 November 2011, 18:32 »
think you might have to get a grinder on the lip on the inside of the turrets. Basically you want them to sit flat against the underneath of the turret. Then drill! 3 holes are enough
when you fit them set them at max caster (the camber can be done on the struts) as that was you will have less camber loss as the wheel rises
I found fitting the topmounts to the suspension a ballache as the threaded holes weren't quite concentric. Basically they are never coming off my coilovers again  :laugh:
« Last Edit: 26 November 2011, 18:33 by veedubgti16v »
VeeDubGTI16v
« Reply #5 on: 26 November 2011, 18:48 »
or you could do that^
Offline JonLeeper
« Reply #6 on: 01 December 2011, 11:12 »
Loving that, any more info or a thread link?
Offline SoundillusioN
« Reply #7 on: 01 December 2011, 13:10 »
^^^ That's had the turrets raised!
VeeDubGTI16v
« Reply #8 on: 01 December 2011, 13:18 »
Thats my old shell, the turrets are in the same place, just flattened!
Jon look for '85 gti in members motors, it will be a few pages back by now, not sure if there are anymore pics though
« Reply #9 on: 01 December 2011, 13:32 »
Apologies.  I thought a bit of THIS had been going on.  Never noticed that mk2's turrets are so much closer to the bonnet than a mk1' s
