Author Topic: Remapping  (Read 28163 times)
jamie16v
Re: Remapping
« Reply #30 on: 21 November 2011, 19:30 »
i understand completely  :wink:
Offline Chris.
Re: Remapping
« Reply #31 on: 21 November 2011, 19:32 »
Certainly interesting to get into if you have the relevant documentation to read through and understand how the ECU works.  I can only mind Me7.1 documentation from bosch and nothing for ME3.8 :(
Only thing is...you will need to find someone to give you a stock AGU map file as you cant read from the AGU 3.8 ecu :(
Click For Build Thread
jamie16v
Re: Remapping
« Reply #32 on: 21 November 2011, 19:48 »
you have pm  :smiley:
jamie16v
Re: Remapping
« Reply #33 on: 21 November 2011, 21:31 »
how would one get a 12v supply to pin 43? would it just be a case of splicing into the loom?...
Offline The Doc
  • E63s Estate - Vito Sport
Re: Remapping
« Reply #34 on: 21 November 2011, 22:22 »
You'd goto the ecu connector, this may end in tears btw.....
WinOLS.
WinOLS what?
jamie16v
Re: Remapping
« Reply #35 on: 22 November 2011, 10:00 »
howcome?....
 i was thinking..i might have a play on my scenic first..  :shocked:
its easier to tap into the ecu and has no boost  :undecided:
Offline Chris.
Re: Remapping
« Reply #36 on: 22 November 2011, 18:48 »
I had a look at a A3 1.8T map I found online last night.....Without map packs in WINOLS.....you might aswell just be looking at squiggly lines lol
Offline dom
  • Back in a Mk4
Re: Remapping
« Reply #37 on: 22 November 2011, 18:54 »
Awaits the 'Help I've blown my ECU' thread.... :lipsrsealed:
jamie16v
Re: Remapping
« Reply #38 on: 22 November 2011, 19:55 »
i am not going to even attempt it without all the relevent information. i dont really want to map my car, i just want to learn a little about tuning. at this stage i would leave it to the proffesionals.  :smiley:
jamie16v
Re: Remapping
« Reply #39 on: 22 November 2011, 20:57 »
apparently, jumpering pins in the obd port can get you there.  :wink: best leave it as that though.. :embarassed:
