Author Topic: diagnostics pin on a 1995?  (Read 2365 times)
Offline AdamBeevers
« on: 18 November 2011, 18:32 »
got a match 1.4, trying to find the diagnostics plug, snap on's tool reckons it does have it, 'near cigarette lighter' or something along them lines it says. now, i know my mates was just about the lighter, but mines solid plastics and definitely doesn't have anything behind it.. anywhere else it could be or does it not have one?
taaa
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: diagnostics pin on a 1995?
« Reply #1 on: 18 November 2011, 18:50 »
If you pull the ashtray out the panel above cig lighter should slide to the right and reveal socket.
Or if its an early one try behind blanking switches under heater controls.
« Last Edit: 18 November 2011, 18:54 by Gti_Jamo »
Offline AdamBeevers
« Reply #2 on: 19 November 2011, 11:47 »
had another look, nothing.. :(
Offline Seanl
« Reply #3 on: 19 November 2011, 13:26 »
Glove box or around the fuse panel maybe?
Offline Khare
  • The bear that khares
« Reply #4 on: 19 November 2011, 13:43 »
Do 1.4's even have vagcom port?
Offline Dan_GTi8v
« Reply #5 on: 19 November 2011, 14:06 »
yeah they do my mates one is next to the ashtray behind the blanking plug like normal. its a 97 P reg though
Offline patryk92
« Reply #6 on: 23 November 2011, 01:06 »
on my 1.4 n reg, it was right next to the ashtray, on the left, the cover just slides to the right and the plug should be there..
Offline CM690
  • Golf MK4
« Reply #7 on: 23 November 2011, 11:04 »
Yeah this is where mine is on my P reg :)
Offline javalin
« Reply #8 on: 23 November 2011, 11:47 »
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline gti gaz
« Reply #9 on: 23 November 2011, 13:35 »
yep as above  :grin: :grin: :grin:
 Any one in cornwall lets sort more meets!!!!
