Author Topic: mk3 golf hubs on a mk2 golf will they fit  (Read 2257 times)
Offline mk2addict
« on: 18 November 2011, 10:16 »
Will mk3 gti hubs fit on a mk2 gti with the calipers
Offline tshirt2k
  • Been there...Done that...
Re: mk3 golf hubs on a mk2 golf will they fit
« Reply #1 on: 18 November 2011, 11:50 »
You need the wishbones to because ball joints are at a different angle IIRC
Will also give you 5 stud unless they are from a 4stud
Wishbones will make it widetrack and wheels will stick out further.
« Last Edit: 18 November 2011, 14:49 by tshirt2k »
Mk3 ABF 16VT Megasquirt V3
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #2 on: 18 November 2011, 13:36 »
so all you need is mk3 wishbones and hubs, carriers, callipers ?? that makes it wide track ? and 280mm brakes
Offline tshirt2k
« Reply #3 on: 18 November 2011, 14:23 »
You can use mk3 hubs,whishbones etc to go wide track. But it a bit more than that.
Depends wether you want to stay 4 stud or go 5 stud.
Guide Here
I have a mk3 tdi subframe setup that i would sell, that would need carriers and discs to go widetrack and 280mm and stay 4 stud. Driveshaft may also be needed
« Last Edit: 18 November 2011, 14:50 by tshirt2k »
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #4 on: 20 November 2011, 18:34 »
How much you selling that for mate ?
Offline tshirt2k
« Reply #5 on: 21 November 2011, 12:28 »
I'd take £100
