Author Topic: gear linkage and weighted shif rod  (Read 2592 times)
Offline TIM20
« on: 04 May 2005, 12:03 »
I have got a mk2 16v the gear change is good but thought of fitting the weighted rod from a mk3.  Also while im there fitting the bush repair kit.
Dsoes anyone know the part number of the rod to use? cost of this?
Also which places supply the best quality bush repair kits?
Should i change any thing else while im there?
Cheers Tim
Offline Gambit
Re: gear linkage and weighted shif rod
« Reply #1 on: 04 May 2005, 12:37 »
1HO 711 183 is the part number for weighted shift rod
the ball on the end of the relay shaft is a good one to replace, its get of any forward/back play in the gearstick
Offline TIM20
« Reply #2 on: 04 May 2005, 15:32 »
Does any one know how much the weighted shif rod is?
Also will vw stealerships have tem in or should i go some where else?
Cheer Tim
Offline Mr Blue
« Reply #3 on: 04 May 2005, 15:56 »
think they are about 12 quid. or 30 quid on epay  :grin:
try the scrappy first
diagnosis-dub
« Reply #4 on: 04 May 2005, 16:33 »
All shift rod MK3's have them or try the seats and VW caddy vans as these have them too.
mix
« Reply #5 on: 04 May 2005, 16:47 »
And when you have got it from the scrappy you could pocket pay for it legitimately...... :huh:
Offline ...joe
« Reply #6 on: 04 May 2005, 17:17 »
if you have a short shift kit you have to bend the ends of the weighted shift rod to give clearance, but its not hard...
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
mix
« Reply #7 on: 04 May 2005, 18:14 »
is that a bodge you have done.....
Offline ...joe
« Reply #8 on: 04 May 2005, 18:26 »
you know it son!! i live for a bit of bodge!!, seriously though you have to otherwise you cant get it into second or fourth!!
mix
« Reply #9 on: 04 May 2005, 18:28 »
what worng with 1st then third then 5th :huh: :undecided:
Theres nothing wrong with a bit of bodge, im becoming a professional one when i gradiate
