Author Topic: mk3 golf gti anti-roll bars  (Read 2791 times)
Offline lankylari
« on: 17 November 2011, 20:47 »
Do mk3 golf gti 8v 3drs have rear anti roll bars? if not is there a mod to fit one?
Offline harlemex
Re: mk3 golf gti anti-roll bars
« Reply #1 on: 17 November 2011, 21:05 »
I think there is one in the rear swinging arm.
Offline Len
« Reply #2 on: 18 November 2011, 13:16 »
Yes
www.sas.org.uk
www.the-ace.org.uk
Offline tweed
« Reply #3 on: 18 November 2011, 17:02 »
in the rear beam  :wink:
have a good look and you will see it
Offline lankylari
« Reply #4 on: 19 November 2011, 23:17 »
cheers all had a look today when fitting coil-overs.  :grin: how can I change this for a bigger one! as it goes in side the rear beam?
Offline Ess_Three
« Reply #5 on: 20 November 2011, 10:53 »
You can't...
The aftermarket rear ARBs bolt externally to the beam and damper bolts, or bolt through the U section of the beam on some of the more specialist designs.
In either case, it's an additional rear ARB that works along with the standard rear ARB...the front ARB is a relpacement part.
..but gaining motorcycles.
