Author Topic: How do you remove the ignition barrel off the Column?  (Read 3621 times)
Offline dragongreengolfgti
  • my golf gti mk3
« on: 17 November 2011, 20:04 »
I've tried to take one off my old gti so that i can help someone on saturday hopefully fix there car! so far i've just taken the column completeley out it attachess to? Is it locked on some how? or It must come off because you can buy replacements! anyone got any how to pics please cheers
Mike
Offline Khare
  • The bear that khares
Re: How do you remove the ignition barrel off the Column?
« Reply #1 on: 17 November 2011, 22:44 »
Headless screw on it. Needs to be drilled out then replaced by a screw I think.
  • my golf gti mk3
« Reply #2 on: 17 November 2011, 22:47 »
cheers got this screw out already though still cant get it off its as if theres something else holding it together  :sad:
Offline javalin
« Reply #3 on: 18 November 2011, 10:51 »
the barrel might need to be in a certain position (i.e. run or ign on) - to be removed from the column.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Misky
  • MK3 16v GTI FTW!!!
« Reply #4 on: 18 November 2011, 11:17 »
This! It locks in postition It will need a good wiggle & pull!
MK3 16v GTI FTW!!!
Offline Seanl
« Reply #5 on: 18 November 2011, 11:29 »
Yarp! Steering lock is just a spring loaded piston that goes through a hole in the mounting arrangement. They are a pain in the arse to remove, but thats the whole point. Take the steeing lock off, and it should come out with a bit of jiggery pokery.  :smiley:
  • my golf gti mk3
« Reply #6 on: 18 November 2011, 12:49 »
ok cheeers peps i did think this  myself and  tried to do that perhaps then it needs a bit more persuasion  :grin:
Offline leegt5
« Reply #7 on: 19 November 2011, 19:58 »
You need to drill a hole in the metal barrel housing to release the barrel.. This is from a Seat Ibiza but its the same on the mk3 Golf..
