Author Topic: MFA mpg weirdness and rough running - Coincidence?  (Read 1763 times)
Offline Stirring Moose
« on: 17 November 2011, 20:03 »
Hi everybody. First up sorry I've not been around Golf-land much recently. Have had some terribly tedious "unemployment" issues to deal with  :sad: Anyway, back in business now and dear 'Valver, doubtless smelling the fresh money, has gone wrong. Went to start it up for the first time in a while and it's running rougher than hell, so bad I just shut it down, didn't even want to wait for it to warm up. Just before I put the car away, it was running fine and passed an MOT with a nigh on perfect set of emissions figures. Only odd thing I noticed was that the MFA mpg readout was very optimistic and not very stable. Have done a search for this and have seen people refer to a temp sensor failing and sending the MFA a bit nuts. Wonder if this has occured and is now causing the running prob as well? Any thoughts on this or any other suggestions much appreciated.
S.M.
Love and hate, war and peace, joy and sadness... all just crap that happens between trackdays!
Offline harlemex
Re: MFA mpg weirdness and rough running - Coincidence?
« Reply #1 on: 17 November 2011, 21:21 »
perhaps you should start it up again and let it run. I think your ecu needs to re learn its stuff, if ya get me.  :smiley:
« Reply #2 on: 17 November 2011, 21:46 »
Interesting, hadn't thought of that one. She's been laid up for longish periods before though and never complained at being woken up. Also, it's smelling quite fuelly and I'm a bit nervous of blowing the cat full of unburned fuel and wrecking the thing.
S.M.
Offline harlemex
« Reply #3 on: 17 November 2011, 21:54 »
should be okay while engine is still cold, it will blow it through.  :cool:
« Reply #4 on: 18 November 2011, 00:01 »
Let it warm up again, if still not right then try a new temp sender.
« Reply #5 on: 18 November 2011, 16:42 »
Thanks Wayne. Afraid warming up now isn't an option though - she is now having a complete tantrum and refusing to start at all! :angry:
S.M.
VW BUSH
« Reply #6 on: 18 November 2011, 16:47 »
You checked for a spark? not unknown for ignition module or leads to break down if left standing
« Reply #7 on: 18 November 2011, 17:09 »
Hmm, interesting. Leads should be ok as they are pretty new. By ignition module do you mean the coil pack? Replaced that about five years ago so it's still young-ish and I don't recall any rough running prior to the failure of the last one. However, I firmly believe coils are weird and will go wrong how they like when they like so it's not out of the question.
S.M.
VW BUSH
« Reply #8 on: 18 November 2011, 17:19 »
5 Years is old for coil pack, check for spark and rule it out :smiley:
Relays might be worth a check too
« Reply #9 on: 23 November 2011, 17:44 »
Update: I ran out of time and facilities so Golfy has departed on a trailer to be tended by Them Wot Know. Unfortunately she's leading them a fair dance too. Apparently spark is fine but the motor is epically overfuelling for reason or reasons currently unknown.
S.M.
