Author Topic: CLUTCH PEDAL STICKING ???  (Read 2181 times)
Offline capone
« on: 16 November 2011, 19:47 »
Anyone had any probs regarding a sticky clutch pedal mine seems to stick 3/4's of the way up n releases when accelerating a bit harder or braking or flicking it back up with my toe !!! Possible causes system needs bleeding ? or the slave cylinder ? anyone any ideas HELP !!!
Offline sharki786
  • GOT BOOST??
Re: CLUTCH PEDAL STICKING ???
« Reply #1 on: 16 November 2011, 20:48 »
what car? spec?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Adam
« Reply #2 on: 16 November 2011, 20:50 »
My 350Z did this countless bleeds and I got nowhere. Turned out to be the slave cylinder.
Down Hill From Here.
Offline capone
« Reply #3 on: 16 November 2011, 21:25 »
sorry mk4 2.0 gti
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 17 November 2011, 17:45 »
aint that a cable clutch? if it is then the cable is sticking if not then i dont know :undecided:
*****MK4 GTI T*****
« Reply #5 on: 17 November 2011, 23:46 »
sorry mk4 2.0 gti
I am 99% sure that is a hydraulic set up in which case bleed it first and see if it makes a difference.
