Author Topic: best bang for buck turbo for AGU  (Read 2534 times)
jamie16v
« on: 16 November 2011, 19:33 »
o.k, i have a low budget to spend on a turbo..
my spec to match will be :
calibra injectors
vr6 maf housing
fmic
007p
enclosed cone filter / or moved to cooler loc.
i would prefere to keep the k03s platform, ie, manifold TIP ect so i dont have to spend out again..
how much do you think it would cost me to hybrid my k03s and what sort of power should i expect?..
cheers, jamie.
Offline Scott D
Re: best bang for buck turbo for AGU
« Reply #1 on: 17 November 2011, 01:21 »
last time I looked at hybriding it was around 600 + a k03/03s and 260-280 seems to be the result with bigger maf, injectors and fuel pump after mapping.
k04-001 makes sense (IMO) as its an almost direct replacement for the k03 and with supporting mods 250-260 must be possible without all the hassle of going k04-023 nor trusting that the hybird has been manufactured correctly.
840 for a new k04-01, sell the old turbo for a ton and its close to hybrid costs
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #2 on: 17 November 2011, 22:44 »
Bolt a k04-023 cold side on your k03s or a ko3... :wink:  Not tried it with a k03/s yet but doing this with my k04-001 made 300bhp.
Nick
 01455 617233
Offline Chris.
« Reply #3 on: 17 November 2011, 22:51 »
Hmmmm, wonder if it would work on a k03....>I happen to have a spare in garage.
Exhaust turbines the same size on a 3s to a 04-001?
Click For Build Thread
jamie16v
« Reply #4 on: 18 November 2011, 14:41 »
no, only the 3 and 3s share the same turbine..
Nick
do you think it would really be worth it?..  i was thinking of going with something like littco`s setup with a full k04-023 in a k03s housing?..
jamie16v
« Reply #5 on: 18 November 2011, 20:48 »
sod it, it`s less work for me to just just bolt 023 onto the k03s..... would be fun to see and would be different too...  :lipsrsealed:
