Author Topic: digi and k jet head???  (Read 1258 times)
Offline danny gti 8v
« on: 03 May 2005, 22:18 »
any one know if the head off a digifant engine is the same as off a k jet engine? i was told the digi has the injectors in the inlet but k jet is in the head?? any one know? cheers! :huh:
Offline ...joe
Re: digi and k jet head???
« Reply #1 on: 04 May 2005, 18:16 »
not sure on the differences but they cant be swapped.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
« Reply #2 on: 05 May 2005, 15:03 »
The injectors are in the same place in the head, but I think they are a different shape.  If you can remove the inserts and fit the correct type for your injection system then I think you can swap them over.  I might be wrong on that point though, I'm sure theres a little more to it.  Actually thinking about it you might have a problem with the rocker cover, I think the mounting brackets for throttle linkages etc are different between the two.
