Author Topic: Time to get something from my engine!!  (Read 3245 times)
Offline mrshaneyp
Re: Time to get something from my engine!!
« Reply #10 on: 15 November 2011, 17:57 »
im with elephant.co.uk! none my mates can believe it being so cheap!!, an that's what I was thinking I would think its only the front end side of things? and I'm planning on upgrading my exhaust system anyway, and I've got racing suspension?
Offline T_J_G
« Reply #11 on: 15 November 2011, 18:03 »
Hi; I have a 1.8 Gti (n/a) [125bhp] and im now looking to push some power/torque from the engine;
my aim is to get her remapped but before that I wish to make some changes to get as much gain as possible.
I been told I can;
upgrade to green-top injectors,
K&N air filter/ cold air induction kit,
Sport cat/ straight through exhaust,
FSE boost gauge(this is a maybe),
If fitting the first 3 mentioned in opinions would I see much gain not as in bhp but in acceleration?
then the fact i would get the remap would this be beneficial? thanks !!
Whoever told you to fit a boost gauge is clearly a plank.
You have no boost to gauge.
Flog it and buy a 1.8T
Offline Chris#101
« Reply #12 on: 15 November 2011, 18:16 »
N/A Tuning= £££££ big bucks from experience
*High lift cams
*Stroker rod kit
*High comp pistons
*ITB's
*Stand alone ecu
*Head modifications (port&polishing&gasflowing)
*A good exhaust system not your ebay junk!
But likes been said its crazy money for the equivalent power in a a turbo'd motor
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Ant1981
  • Feed me, prod me
« Reply #13 on: 15 November 2011, 18:22 »
Remap on a non turbo will be about as much use as a hand brake on a canoe   :grin:
Rubbish.
It'll smooth out the engine responce especially after any engine tweaks, can make a good difference, though not as massive as a turbo map.
'09 Kawasaki Ninja ZX-6R
Offline rockmonkey69
« Reply #14 on: 15 November 2011, 18:28 »
Not sure what suspension you got but in what way is it 'racing suspension'?
« Last Edit: 15 November 2011, 18:40 by rockmonkey69 »
Offline xxChrisxx
« Reply #15 on: 15 November 2011, 20:19 »
Springs coloured red innit! :laugh:
Offline Dave_IOW
« Reply #16 on: 15 November 2011, 22:31 »
I been told I can;
Think he means FSE power boost valve  :afro:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline mcgee9t2
« Reply #17 on: 15 November 2011, 22:56 »
I been told I can;
do they actaully work or are they just a waste of money?
Offline mrshaneyp
« Reply #18 on: 16 November 2011, 10:18 »
yeah i did mean the boost valve but as i thought its pointless mod, so ant1981 id see some change in accelration possibly? and the suspension i have is the Apex RDX i believe (yellow springs) came with her when purchased.
Also would a AUM conversion be seen as a non-original engine replacement? as its still a golf gti engine? (worth an ask) cheers! :)
« Reply #19 on: 16 November 2011, 10:29 »
Of course it would, both the DVLA and your insurance company need to know.
