Author Topic: Battery - Starter or altenator whats causing the problem  (Read 2239 times)
Offline Bigdunc
ok guys i recenely fixed my car to find now i get a single click after turning key
I tested battery and its readying 12.88v not sure what the amps are, i charged battery up to 13.33v on my home charger and car starts at 13.33v so i have the car running for 15 mins doing altenator tests
with car at idle i get betweek 13.70-14v with lights on it dosent make much difference and reving the engine it dosent change much iver
now i turned the car off for few mins and then went to start again and just get a click from the starter
it seams iver the battery isnt holding a charge or the starter motor is needing about 13v to start the car
or even the altenator isnt charging the battery enough, but to me it seams the battery is losing charge but it still shows more than 12.5v
can anyone shead some light :)
Offline The Mighty Elvi
  • I'm better than you today.
Re: Battery - Starter or altenator whats causing the problem
« Reply #1 on: 14 November 2011, 18:14 »
Read my post:
http://www.golfgtiforum.co.uk/index.php?topic=174652.0
Process of elimination.
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #2 on: 14 November 2011, 19:02 »
Sounds like the starter to me
Offline Bigdunc
« Reply #3 on: 14 November 2011, 19:35 »
ok my mate come over whos a mechanic we plugged the battery back in and it started first time, strange as hell as he didnt actually touch anything lol, while we got the car started he had a look at voltage he said that seams about right, we turned it off and on again few times to check it started and seamed ok, he did say if it dosent start again tap the starter motor as it could be on its way out, so im going to give it a try in the morning see if she starts if not then ill look in to changing the starter motor
Offline walchy01
« Reply #4 on: 14 November 2011, 20:25 »
Had my Bosch starter motor re vamped for just £30 and its good as new,starts first turn now, may be cheaper than replacing :wink:
Offline Bigdunc
« Reply #5 on: 14 November 2011, 21:33 »
well since i owned the car, ive fitted a new bosch and that went then only one i could get was a soverign and thats the one that seams to be playing up now so think might look in to a high torque starter or just another bosch
Offline AudiA8Quattro
« Reply #6 on: 15 November 2011, 10:18 »
Are the points in good condition? as in the starter solenoid.
Had this before on a mk2.
Offline Bigdunc
« Reply #7 on: 15 November 2011, 18:31 »
I'm going to upgrade the cable from battery to starter at weekend and also double up my earth cable to gearbox :) so hopfully this may help it start
« Reply #8 on: 16 November 2011, 21:47 »
Make sure the points are clean and shiney for a start.
Offline Bigdunc
« Reply #9 on: 18 November 2011, 19:33 »
im gonna clean up all the points, funny enough since i posted this thread she dosent seam to bad, im gonna keep a close eye on things for a while i think
