Author Topic: my coilovers  (Read 2081 times)
Offline mush
my coilovers
« on: 14 November 2011, 11:38 »
quick question ive had my coilovers on my car for around 3 years now and still arent in bad condition. i was thinking of dropping it down a bit more but didnt want to start and run into trouble if they are seized up.
shall i have a crack at this or do you think it'll be more trouble than its worth,
just to let you know it wasnt for a few mm its going all the way down or nothing at all  :grin:
MK2 golf 16v :-)
Offline sharki786
  • GOT BOOST??
Re: my coilovers
« Reply #1 on: 14 November 2011, 13:12 »
if you aint put any copper grease on when you 1st put them on then they will be seized up like a beech. used wd40 and let it soak for some time
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline mush
Re: my coilovers
« Reply #2 on: 14 November 2011, 13:24 »
not sure if they had copper grease on they were on from previous owner,
i think i might give this a go, i just didnt want to get to the last one a be swinging off it.
MK2 golf 16v :-)
Offline Junior74
Re: my coilovers
« Reply #3 on: 14 November 2011, 13:25 »
Go for it!!!!!!
Re: my coilovers
« Reply #4 on: 14 November 2011, 13:48 »
If they were not greased / copperslipped from new I doubt you will get them to move.
Offline harlemex
Re: my coilovers
« Reply #5 on: 14 November 2011, 15:38 »
hammer and screwdriver (hardened type)
Offline Khare
  • The bear that khares
Re: my coilovers
« Reply #6 on: 14 November 2011, 17:18 »
Use plusgas rather than WD40. WD40 is a water disperer, not a penetrating lube (Use KY for actual penetrating lube).
Offline tweed
Re: my coilovers
« Reply #7 on: 14 November 2011, 17:49 »
and plenty of it. leave it for hours and keep adding.
Also wire brush the threads  :wink:
Offline Bellend
Re: my coilovers
« Reply #8 on: 14 November 2011, 18:45 »
Mine have never seazed because they're not cheapo tat and I copper greased all the threads. A quick wipe off the dirt and they move fine. Then just re copper grease all the threads and adjust.
Where all my moneys went.
Offline NERF 69
Re: my coilovers
« Reply #9 on: 14 November 2011, 20:25 »
I think you'll have a bit of trouble i have the same problem with mine and no amount of wd40 will help you. Taking them off the car and soaking them in diesel is your best bet if you really want to do it
Sell my Vw??? I'd rather stick wasps up my arse
