Author Topic: Workshop lighting  (Read 1365 times)
Offline popleyruss
Workshop lighting
« on: 13 November 2011, 19:37 »
I've had enough of the shocking lighting in the workshop and need sum advice I have 3 normal lights in there at the min and is it as simple as changing the roses to strip lights ??? I'd like to run 2 maybe 3 on the Walls aswell
Hears a pic of the size of the place
As u can see the lighting is shocking
Just plain dubbin
Offline Diamond Hell
  • Opinions я Us
Re: Workshop lighting
« Reply #1 on: 13 November 2011, 19:41 »
Unless your eyesight is terrible find some secondhand sodium flood units.
Just installed them in the barn in which I muck about with cars.
They are a LOT better than the 500W floodlights I had in there previously and use much less electricity.
You might also like to put a couple of tubes in at waist height (with diffusers on them).
Offline Ess_Three
« Reply #2 on: 13 November 2011, 20:04 »
I bought 30 low energy lamps (75w equiv...14W low energy, I think @ 10 for £1), a roll of 1.5 T&E cable and some angled mounts from Screwfix and installed 20+ lamps for around £50 and a days work...it's like daylight in there now, as you can see:
..but gaining motorcycles.
Offline bobbarley
  • I'm kind of a big deal...
« Reply #3 on: 13 November 2011, 22:06 »
That's a lot of power cables and plug sockets!  :grin:
Offline popleyruss
« Reply #4 on: 13 November 2011, 23:43 »
Cheers guys I think diamonds way will be better think I'm gonna use 3 strip lights replacing the 3 normal bulbs I already have and then run a few at waist height
Just plain dubbin
Offline danny_p
« Reply #5 on: 13 November 2011, 23:54 »
about the right amount.
lighting in my workshop is terrible atm,   had to open the door up so all the wiring had to be disconnected. think i'm going to stack lots of floresent units
all the VW's have gone bar 1.
Offline luke
  • When in doubt, whip it out!
« Reply #6 on: 14 November 2011, 00:38 »
I have a twin set of flood lamps in my garage, works really well and especially when it's cold you stand infront of it and it warms you up, also have a small lamp that just attaches to a bonnet or surface and connects to the car battery, handy to have especially in the winter nights
1985 mk2 gti type 19 8v
2018 t roc sel 1.6tdi
