Golf mk2
will swapping heads work?
Topic: will swapping heads work? (Read 3670 times)
mattdebs
1991 MK2 8v
12 November 2011, 23:32 »
My cambelt snapped today
Gunna get quotes for fixing it and I'm looking for a new engine incase it works out cheaper. Do i need a complete lump or can I just swap the head for another?
Thanks in advance for the help
herr schimdt
Re: will swapping heads work?
12 November 2011, 23:53 »
as long as the pistons and bores are fine then you can just put another head on if the valves are fine then all youll need is a new headgasket and cambelt
weazgti
13 November 2011, 08:39 »
is it 8v? apparently they are non interference and some people have got away with just changing the belt. could you try a belt on or is it beyond your capabilities?
mattdebs
1991 MK2 8v
13 November 2011, 08:57 »
Yes, it's 8v, I reckon I could change the belt easily enough, it's just setting up the timing I would have problems with. Be great if it is non interference.
Diamond Hell
Serious forum addict
Opinions я Us
13 November 2011, 11:45 »
Get the Haynes out and just rotate things around where they need to be, then put the belt on.
The only tricky bit will be timing in the dizzi, as it's unlikely to remain as it was.
siddleg
13 November 2011, 12:28 »
is that right re 8v non interference?
Diamond Hell
Opinions я Us
Reply #6 on:
13 November 2011, 13:02 »
IIRC yes it is.
herr schimdt
Reply #7 on:
13 November 2011, 20:08 »
d the haynes manual its got all the info to change the cambelt and yes it is none interferance
http://www.golfgtiforum.co.uk/index.php?topic=189837.0
Bigdunc
Here all the time
Reply #8 on:
13 November 2011, 20:28 »
put new belt on and turn engine over by hand if all seams smooth and nothing nocking then your prob safe
Wayne
Sir Postalot
Reply #9 on:
13 November 2011, 20:48 »
Quote from: siddleg on 13 November 2011, 12:28
Correct, how fast were you going at the time
Golf mk2
