Author Topic: Am i been naive  (Read 3661 times)
Offline siddleg
Am i been naive
« on: 12 November 2011, 16:12 »
Evening all
I changed to clutch cable on my 8v gti about 3 months ago seemed like an easy enough job but now the clutch has started slipping could i of adjusted the cable wrong? or is it just coincidental?
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Am i been naive
« Reply #1 on: 12 November 2011, 16:20 »
did you fit a self adjusting cable or a standard one??
Self adjusting ones have a big cone section above where it fits to the box..
If it's a standard one it will need adjusting every so often...
HTH
For More Info Click To See;
Offline herr schimdt
Re: Am i been naive
« Reply #2 on: 12 November 2011, 17:48 »
you say it was changed 3 months ago was it slipping then basicly as the cable is used it can stretch that would cause you to have to push the clutch in thurther to make it disingage then you adjust it so the clutch disingages closer to the top of the pedal the only way the clutch could start to slip is if its knackered or the calbe has got shorter you could try loosening the cable but highly likely that you need a new clutch plate. do you drive like a racing driver or my dad as racing drivers wreck clutches my dads clutch would last 30 years
Offline siddleg
Re: Am i been naive
« Reply #3 on: 12 November 2011, 17:49 »
i think it was a standard one which i had to adjust till the peddle felt right
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Am i been naive
« Reply #4 on: 12 November 2011, 18:01 »
Cable needs adjusting again... Mine does this every 6-12 months...
Offline Diamond Hell
  • Opinions я Us
Re: Am i been naive
« Reply #5 on: 12 November 2011, 18:18 »
Or possibly the clutch is gone.
When was it changed last?
Offline siddleg
Re: Am i been naive
« Reply #6 on: 13 November 2011, 12:24 »
The guy i bought it off in March 2011 said it had been done not long ago but nothing in file
bummer more expense  :cry: as its not something i can do myself
never mind
cheers for your advice
  • Opinions я Us
Re: Am i been naive
« Reply #7 on: 13 November 2011, 13:02 »
Well make sure you adjust the cable first!
Offline siddleg
Re: Am i been naive
« Reply #8 on: 13 November 2011, 16:47 »
surely adjusting the cable now will make no difference will it ?
Offline tech1889
  • Mk2 GTI FTW !!
Re: Am i been naive
« Reply #9 on: 13 November 2011, 17:31 »
yes you could be riding the clutch making it slip
