Author Topic: Which BCM for rear LED's  (Read 1692 times)
Offline EyeballPaul
« on: 12 November 2011, 13:09 »
Hi all,
I am about to fit rear LED's to my car it is a June 09 reg so will probably need a BCM upgrade, i will get this confirmed next week when SteveP comes over to do the coding for me,
Which BCM's are compatable, i am watching a few on Ebay.de, Steve said a 087D would be fine, but i am watching a 087E and some 087C's, will these work. Is there a list of numbers that will work,thanks
Paul
Jimmymature
Re: Which BCM for rear LED's
« Reply #1 on: 12 November 2011, 13:48 »
I bought the D version, I think it supports Xenons but not the fairy light versions.
If in doubt PM SteveP or mike and they can tell you for sure.
Edit: forgt to say Darren also an expert on this sort of thing...
Jim
« Last Edit: 12 November 2011, 16:43 by Jimmymature »
Offline mortygt140
« Reply #2 on: 12 November 2011, 15:27 »
087R Z0E seams to be the new version with all the LED activation. Its hard to say has the part number is nothing without the end 3 digits for the spec revision i.e the number I gave has Z0E on the end that means it has every thing including climate control, xenons, rear LED licence plate and LED rear lights plus allsorts of other things....But the same part number with Z0B on the end has nothing manually controller heating, halogen lamps standard rear lights :undecided:
Darren
« Last Edit: 12 November 2011, 15:30 by mortygt140 »
